ClassyGlassy
- Joined
- Feb 21, 2010
- 383
Hey guys, I got it running today and after about 45 seconds I shut it down......here's why:
1. No water coming out of the "pee" hole
2. Light smoke starting coming from around the coils, behind the coils and against the exhaust plate are two boxes between the plate the coils are mounted on and the exhaust plate itself. They both have 2 Red wires, 2 Yellow wires, and 1 Grey wire. The top one's Grey wire is connected to the harness that the other wires go into while the bottom one's Grey wire is plugged off. The bottom one was shooting a reddish orange flame and smoking badly.
I have removed both boxes to find the top one has some damage where the gel has started to crack from getting hot probably from the initial damage from before. I'm assuming that that one will still work O.K. But you can see the damage of the lower one that was burning and that it needs to be replaced. Numbers on the boxes are 815279-3 and 2694.
Any and all help with identifying these boxes and if I have to get used ones to keep prices down would be much appreciated.
Thanks
Thanks
