Still have water in l/u
leatherneck46
I have changed foward/reverse gears and replaced clutch dog.Resealed everything real good. I was told that the prop seal is good (by my dealer). Installed new seals in fill/drain plugs.<br />Can water be getting in through the water pump area? When I removed the boat from the water I can see water/oil weeping from a small hole next to the fill hole on the l/u. When doing a preasure check should the l/u be off and in water? Any Ideas?<br /> Thanks Rod
R.Johnson
Re: Still have water in l/u
You can have a water leak around prop shaft, drive shaft, shift rod, prop shaft bearing head, you have to check them all
