johnsonjunk88
- Joined
- Apr 24, 2008
- 23
I would appreciate any help and patience with ongoing problem until my shop manual comes in Friday. As on other posts engine is not getting any fuel, replaced VRO Pump with new four wire pump. Engine is getting plenty of fuel and oil. But now as soon as I turn the key on, alarm is going off even without the engine running just key on. Constant alarm overheat or no oil. Both is okay. Pumping plenty of oil and engine is running at temperature, but the alarm will not go off. Back to the same issue, engine is still surging from idle or when running full thortle. Engine will cut right out after reduced power back to an idle, engine shakes voilently, where it shakes the steering wheel right out of your hand. This problem has no pattern to it. Sometimes it will do it when engine is cold or when hot, idling, half thortle WOT. I was told this may be a problem coming from the power the pack and or the voltage regulator. Any truth or fact to this? I looked at both pieces and noticed the voltage regulator through the sealed rubber, you can see some of the electrical connections, and it looks to be rust starting on the sauder connections. Is there any way to check these parts with a volt meter? And is there any truth that these two parts can cause this problem?
Thanks a million trying to go fishing this weekend.
