If you look back on earlier post I had I have a 1991 40hp that had the powerhead replaced with a 48hp one. It runs pretty good at the higher RPM's, but the idle wasn't/isn't right. I have been having the suspicion that it was ignition not fuel and it looks like I was correct. Today I replaced the plug wires, checked for a leak at the carbs and just tinkered with it for quite some time. Here is what I found out....Hooked a tach to it that read off of the spark plugs....it's for 4 strokes, not 2 strokes....so that is why it is high, but here are the numbers, about 1800-1900 on the lower cylinder and (here is the kicker) about 2800-3000 on the top one. Since it is idling at about 1000 give or take depending on which tach I use (a mechanical on the flywheel or the boat tach) I assumed that the upper cylinder was double firing for some reason. I hooked up the timing light to the #1 plug and sure enough....it was firing every revolution just before TDC but running the timing light around the flywheel it is also firing, I guessing based on the position of the timing mark, just as the piston is starting to "come back up". That explains why I had to advance the timing so dang far to get it to idle....it brought it closer to the beginning of the piston going up having less affect on the way it is running. This is not good since it puts my boat down until I get this figured out, I don't see any signs of detonation on the plugs though, so hopefully nothing is damaged.
SO...any ideas on this one? I have already changed the ignition module...what else? The bottom cylinder is firing correct, so what is messing up the top? Now I am really confused.
-Aaron
-Aaron
