DAN M VAGOS
- Joined
- Jul 11, 2008
- 363
Just had the boat out on the lake it still has the same problem bogging down upon accelerating. Please read my last post to get filled in on everything that was done. I just got it back from the dealer again he told me that they did another fuel filter, some type of fuel strainer and also reset all linkages back to factory spec. Timing is dead on the compression is perfect The plugs are new CDI box is brand-new. He tells me he did all this for free because I've complained but in taking the boat out for a ride tonight it's the exact same problem all over again. I will say I figured out how to not make it do it. Okay so the boat starts and runs great if I stop and fish for about five 5 minutes and try to restart and take off slow it bogs down installs Will do this every single time. Today I figured out if I start it up in and just drop it in gear and go it's fine it seems to only be when I restart and try to take off slow is when the motor will just bogged down to where it stalls out and priming the fuel ball and choking it does not help. So I drove across the pond back to the dealer and he tells me I need three brand-new carburetor and possibly a Vro pump.now can someone tell me please vro pump is also a fuel pump correct ? And if it was not working the engine would not run? I'm kind of stuck and just looking for what I should do next unfortunately I am laid off right now and money is a little tight. And the close to 900 I just put into the boat and did not fix it so I kind of want to know should I just do the carburetors or should I just do a VRO . I know we're just throwing parts at it but I need it fixed and he's not willing to help me he just says you need new carbs and possibly a vro and is not willing to guarantee anything. Please give me a direction .. Thanks to all you
