Still overheatin
redneckn
1984 merc V6 installed temp gauge runs 3/4 on gauge at idle. Once on plane slowly moves to hot shut down motor before buzzer goes off. New w/p kit including housing,new pickup tube runs 12-15 psi at wot pressure.Compression good,135-140 all cyl.Good spark timing set dead on,Any ideas/suggestions taken. thanks in advance
redneckn
Re: Still overheatin
150 hp ser#6296484 if this helps any 2.4 litre
Fouled Plug
Ensign
Sure the temp gauge is accurate? Also, could be a stuck thermostat.
redneckn
Running motor without t-stats for now until i can solve this problem. The powerhead is freshly rebuiltmaybe just tight?
