After changing the water pump in my 1970 Evinrude 4 hp, the engine began to overheat when run. A good spray of water comes from the exhaust, but it comes out cold, while the powerhead gets very hot, too hot to touch. My first thought was that maybe the fuel pump didn't go into the water tube running through the lower unit. But it was and while I had it apart I also rechecked the water pump, and hooked the tube up to my garden hose, water came out from where it should in the powerhead inside the lower unit. But it still overheats. The first thing that I checked was a thermostat but found none on this motor. Could there be a blockage in the head, and the water could be flowing into some sort of relief?
