jesse_boston
- Joined
- Aug 2, 2020
- 78
I'd rather not waste another evening plus gas etc driving to the lake if I can avoid it.
When I bought the boat it seemed to run just fine in the guy's driveway. Heated up to around 175 on muffs and stayed there.
I got it home, dealt with a bunch of other issues, and tested it out in my driveway on the same muffs... it heated up to 180, 190, 200, so i shut it off. Since it was okay on the seller's driveway, I figured that I just didn't have enough flow through the hose.
Headed out to the lake and it ran fine on plane around 170 degrees but as soon as I came off plane the temp alarm went off and the temp gauge climbed and climbed right past 220. I of course immediately shut it down. Everything was too hot to touch. I let it cool for an hour and limped back to the ramp.
I've now put in a new impeller (and complete raw water pump kit) and new manifolds and risers, the old risers were all clogged up with scale and rust and were getting ready to leak. The manifolds looked okay, but it's hard to tell what they look like inside and I couldn't remove any of the plugs to check. Also has a new 160 degree oem thermostat (correct per the Mercruiser parts website)
Testing it on my driveway, it ran well. Same amount of water coming out the back. Heated up to about 185 and stayed there, though the alarm started going off. For 5 or 10 minutes I could put my hands on everything without it hurting, but after about 10 minutes the starboard riser got too hot to leave my hand on it for more than 10 seconds.
Do I just have insufficient flow from my hose? Is there another way I can test this without driving to the lake? Stick the whole butt end of the boat into a big storage bin filled with water or something?
I have not pulled or disassembled the water recirculating pump.
1995 Alpha 1 Gen II 5.7 Thunderbolt IV (0F297698) / Doral 230EX
Thanks!
Thanks!
