Re: Still stumped on engine miss.
I have to try the squirt bottle trick - havent been able to do that yet because it has been raining here. And yes, when I say good spark, I have seen it jump to ground out of the coil pack, blue in color probably almost 3 inches away. I was amazed at the awesome spark it has. That is why I am so pissed off that I am leaning towards a fuel problem here even after rebuilding the cars (properly) without taking any shortcuts at all. Brand new fuel system from front to back including tank, 135lbs of compression in both cylinders, new wires and plugs, (multiple sets when I even second guessed possibly fouling the first 2 pair with all my testing. Your idea of testing the pump off the motor was an awesome one. It passed the non leaking out the back test. however, what move do I make next other than to squirt some gas into upper carb while running? I also like other idea of gravity supplying the carbs and watching performance of the factory pump with hose off while running - that is another great idea!! Thank you all soooo much. Sooner or later I will figure this out, It is going to end up being the last thing I try to test before I find culprit - going nuts on this one.... Ive put together motors brought to me in milk crates, but cant figure out a miss in a little outboard... LOL
