wildways1976
- Joined
- Jul 25, 2009
- 20
Well we put the boat in the water today, it ran real good ecxept the hub in the prop was bad... We were probably out for an hour. When we has figured the prop was shot we decided to take it out of the water. When we pulled the plugs there was an insane amount of water coming out of the hull... This boat is a 1973 Chrysler (? Model) it has two plugs one in the middle of the hull at the bottom and another at the left of the hull. We had both plugged and dont see any visible cracks in the hull. When he first got the boat it had a pretty sizable area on and around the keel that had been repaired, we the went on and cleaned the area up and layed more fiberglass over the same area to ensure it was covered. Now my question is does the fiberglass have its own seal or do we need to add a sealer after it has set up??? I'm not much of a body man but everything we have done so far has been on a budget....
