Johnson8537
- Joined
- Jun 28, 2009
- 5
Does anyone know what the stock fuel mixture settings are for a 5.7L Merc (95 Tantrum)? I think it is a Q jet.
I had a buddy who thought he knew what he was doing attempt to adjust them as well as the timing was off bit and it didn't want to idle sometimes. ( Other times it was fine.) Now timing is off A LOT and the fuel mixture is also probably off!!
Anyway I need to know where to go back to stock. I am hooking up a timing light today and the cover says 8' BTDC. But don't know how many turns out Stock fuel mixture setting is? once i get everything back to the correct settings I can adjust from there if needed.
Then when i have the mixture and timing correct I can trouble shoot my idle issue. (If it still isn't fixed.)
Any other ideas of why it might not want to idle sometimes and other times it runs and idles fine?
Thanks in advance!!!
