rangerbassman
- Joined
- May 8, 2006
- 34
I just got finished taking three OLD late 60's, early 70's 9.8 motors and making one "running" motor. I am using a powerhead that has the ignition under the flywheel, no coils. I hooked up the water and it started right up. The stop switch on all the motors were in bad shape. There is a three wire harness running from a block on the side of the engine block that used to go to the stop switch. The ends were fraied and I got the wires separated and the engine ran on both cylinders, but at one time I think two of the wires were touching and the engine only ran on one cylinder. That may have just been a fluke. The way I'm thinking is, there is one wire from each spark source that is supose to ground through the third wire when the the stop button is pressed. Please correct me if I am wrong on this because I am thing I may just put the two wires togetherand put in a switch to ground due to not being able to find a stop switch anywhere. I may just asking some sorry parts men or they are not availble. If someone knows where I can get one please chime in.<br />Thanks, Chris
