have a tube type trailer which we use to launch a the ocean. i'm concerned about rust inside the tubing which cant be seen until there's damage. Its my understanding that steel will not rust if there is no oxygen. so i'm thinking if i weld up all openings in the tubing (which now have drain holes in the bottom of the cross members) then weld in access for a schrader valve stem,next use a vacuum pump (which i have) vacuum the air out and inject dry nitrogen to about 5 psi. into the entire frame, i should never have any rusting on the inside of the tubing . . . thoughts?
