Shakedownscott
- Joined
- Jul 12, 2011
- 179
A two week break from my boat project has turned into about two months of not much getting done on it. During this time colder weather has settled in and winter is just around the corner. Instead of working on the boat I have been taking care of all of the typical fall chores. At this point they are pretty much done and I am ready to get back to the boat.
I have about 4 gallons of polyester resin in a 5 gallon pail and approx., 50 lbs of urethane expanding foam. I have stored the expanding foam in my basement, seems to be a good spot to keep it out of the way for now. I had the poly resin down there for about an hour before the admiral told me to get that stinky stuff out of the house.
Luckily I have a furnace in my garage, so I fired that up and I have been storing it out there at around 50 F. I am thinking about moving the resin to (4) 1 gallon containers that previously had resin In them.
I have a few questions that I hope you guys can help with.
1. What is the shelf life of the expanding foam?
2. Whats the best storage temp for the foam?
3. What would be a minimum temp to store the poly resin at?
Hoping to get a lot of work done over the upcoming winter but not exactly sure how its going to work out when its zero degrees out there :smow:
