Stored battery's volt reading
Dirty Dawg
Ok I have a mental block when it comes to electronics, so be gently. My boat batteries are being stored and maintained on a 1.1 amp charger/trickle. What is the voltage that the batteries should have if everything is as it should, 12.75 volts? Just want to check and make sure all is good!! Thanks Ike
Silvertip
Re: Stored battery's volt reading
Good -- but remove the charger and wait half an hour or so before you measure the voltage.
Dunaruna
12.75v is a good resting voltage for a flooded battery but not so good for an AGM or gel.
Dirty Dawg
Yes they are flooded type batteries. I will let them sit and retest. What kind of voltage drop happens to a normal flooded battery just sitting there with no drain. ike
Silvertip
A good battery should measure 12.6 volts. But it can self-discharge over time. How much and over how long a period depends on the age and condition of the battery. Just because it measures 12.6 volts with no load does not mean it's a good battery. Only a load test or hydrometer (a test of the specific gravity of the electrolyte) can tell you if the battery is good or not.
Dirty Dawg
Thanks all for the info. New batteries that worked great last year. Just wondering what I am looking at as I charge them over the sleepy winter. I want to make these last and just double checking what I see as I charge them. I know, from reading these forums that a load test is needed to determine what the battery can do when it is put to work. Thanks again Ike
