Michawilden
- Joined
- Apr 4, 2015
- 153
I have an evinrude 3 hp lightwin in to repair for a friend of mine, He said that it had a problem with the ignition. Only one cilinder had spark. Since he had no clue of the history of the outboard i have pulled the flywheel to inspect the coils and point since these are likely to fail.
As I removed the lower cowling, I already noticed something strange. The spark plug wires did not come from under the timing plate but came from an extarnal coil.
Both spark plugs had an indivual coil mounted on both sides of the powerhead under the tank. Under the flywheel, the original coils where present but stripped down to the primary coil. Using the good primary coil and the external coil the engine could produce a healthy spark.
In the picture I had removed the other primary coil to see how the wiring was arranged. I have never seen this sort of repair and just wanted to share it with you guys.
It is kind of an hillbilly solution but here in the Netherlands one original coil costs 30 euro, around 35 dollars so this is a much cheaper way to repair your motor is you have some spare coils lying around.
