benitez63035
- Joined
- Apr 29, 2012
- 20
Hello guys, just want to say thanks for the all the help in my previous posts.
The Boat info:
1987 Bayliner Capri
1985 OMC 3.0L 4cyl motor
OMC Cobra OutDrive
Now I'm having trouble with my outdrive. When I push the throttle forward from neutral there is a loud, fast clicking noise coming from the outdrive. If I push the throttle forward a little more there is a distinctive loud clanking noise and the clicks and everything go away and the prop starts spinning. (Prop doesn't spin when clicking noise is occurring). Keep in mind this is while running it with a water hose, hasnt been in water since i put on the new outdrive. Would it change if the boat was in the water? Should i try taking it to the lake or will it do damage? I havent taken done anything since i noticed the noise because I dont want to mess anything up!! So I'm trying to look for some help if anyone has had this problem before, if so any help is appreciated!!
The Boat info:
1987 Bayliner Capri
OMC Cobra OutDrive
