I have owned this engine since it was less than one year old. It is used as a sailboat auxiliary.<br />Several years ago it broke a ring and I rebuilt the power head, boring it and adding oversize pistons.<br />There was exceptionally little wear in the lower engine, cross hatching still clearly visible.<br />I have had trouble since getting it to run smoothly and reliably. I have replaced the ignition coils, points and condenser. I have checked the resistance of the driver coil and it is in spec.<br />I think I finally found the rough running problem in that the initial timing was off a little. The ignition was advancing a little before the throttle was opening.<br />At the same time, I noticed that there was a high voltage corona running around the base of the boot on the number one plug.<br />The flashes of the corona were synchronized with misses in the engine. When I pulled the boot off the plug a little to create a gap between the wire and the plug tip the corona disappeared and the engine smoothed out.<br />There are carbon tracks in a ring around the white insulator of the plug.<br />I replaced the plug and all seems to be well, but I don't understand how arcing occurs around the junction between the rubber boot and the ceramic insulator.<br /><br />Anybody seen this before?<br /><br />Thanks,<br /><br />Al<br />
