I have a 50 foot 30 amp power cord and receptacle. I started having intermittent issues with getting a reverse polarity warning and low voltage on my boat. It slowly got worse over the last 2 weeks. It went from getting a reverse polarity light if I turned on anymore more than a small overhead light to getting the reverse polarity light if I just had the main breaker switch on. I checked everything on the back of the AC panel and everything checked out fine. I did some diagnostic work and did some testing with a volt meter.
With the power to the plug, the end of the plug unplugged from the boat I get the following readings.
Black to ground - 120v
Black to white - 120v
White to ground - 0v
So that tested fine. So then I plugged the cord back into the receptacle with the main breaker and all of the breakers turned off on my AC panel. I took a reading from the back of the receptacle on the actual screws that hold down the wires.
Black to white - 41v
I thoroughly cleaned the contacts on the receptacle and on the cord and got the same 40 to 42 volt reading on black to white.
Could the receptacle be bad? Is there anything else that I can try?
