Hi to all again
I had fixed my engine with your help in my previous post.
http://forums.iboats.com/showthread.php?p=2884797#post2884797
Now I have a new problem
As I write before I had disable vro with the steps you recomended.
This problem happened twice, when I have 1 week to use the boat , ( I have it at home in a treiler ) when I start the engine, ( it starts fine ), and try to open full trottle, the rpm is limited in about 3000, no alarm, no light on the panel, this happens about 5 minutes, after that the engine suddenly starts running like a charm, as many hours as I want to use it no problem WOT at about 5500-6000rpm.
Second time tried to use it exact the same problem.This time I tried this. I let the engine in the sea in the dock, and I was using it every day for four days ( I was going fishing ) for 3 - 8 hours every morning the engine was perfect, no problem at all
I don't know what to think.
I think SLOW was activated, but why? it happenes only with cold engine
I had tried to ground the tan wire comming from the heat sensor, only the "hot" led lights.
But when the problem occurs no light at all.
And another question, is it necessary to warm up the engine 5 minutes before I open full trottle?
Thank you in advance
Leonidas
Leonidas
