Mischief Managed
- Joined
- Dec 6, 2005
- 1,928
Helping a friend troubleshoot his 4.3 MPI engine that is not making full power. My TechMate scanner shows no fault codes, the TPS, air temp, MAP, coolant temp all work normally. The IAC is no good, but that just affects idle speed and I don't think it is causing the lower power on plane. Tried doing an induced misfire test with really strange results. IF I induce a misfire on cylinder 1, RPM drops from 1600 to less than 600 and the engine sounds like it's going to die. If I induce a misfire on cylinder 2, the RPM just drops a little. If I try the test on any other cylinders, the TechMate tool outputs a "function not supported by this ECM message". Any idea what this test is really doing on the ECM555 equipped engine? The manual says it's supposed to shut of the injector of the selected cylinder, but I cannot image why I can't test cylinders 3 through 6.
