Tacklebuster
- Joined
- Feb 4, 2005
- 31
I have a 05 150 4 stroke. I put about 70 miles on her on an ocean trip last week. At the ramp while the motor was at an idle, I heard a light whining noise from the top of the motor. I took the cowling off and removed the plastic cover to reveal the belt and pullies. The whining noise seemed to come from the belt. I sprayed some belt dressing on the belt but the noise was still there. Upon further inspection, I think the noise is coming from a small steel wheel that the belt turns. <br /><br />Anyone know what this wheel is? If you are standing in the boat and looking down on the motor, it is located on the left hand side about midway down. I sprayed some WD-40 around that wheel but it still seems to whine a little bit. It only really whines loud enough for you to hear it after a long run.<br /><br />Also, after running her for about an hour and a half or so and you shut the motor off, it is a little hard to get back started. If it sits for about half an hour or so it fires right up
<br /><br />Thanks...
