Help. This old boat (1977 Carver) has taken over running itself! I can turn on the house water and the battery will appear like it has run down after 20 seconds, I turn off the water and wait and everything is fine. My Nav lights blink on and off some times. The instruments jump all over the place and the bilge pump only acts like it is getting partical voltage. I will hit some rough water and the problem fixes itself. I get back to the dock and it reappers. I have spent hours and hours with a volt meter checking things with no luck. I got mad and hit my instrument panel with my fist and it fixed itself (for an hour). Removed instrument panel and all checked out ok. Bad ground or Bermuda Triangle? any ideas? Battery check Ok.
