Stringer boot recommendations?
UtTex
I'm fixing up my 79 Starcraft Chieftan and I'm at the point of installing a new rubber boot for the OMC Stringer outdrive. Unfortunately, the new 22-hole aftermarket boot I bought doesn't fit at all. I was prepared for the holes not to align but I can't overcome the fact that the corner radius doesn't match up at all with the metal gasket ring (of which I have two and they are identical). Does anyone have a recommendation for a well-made replacement boot? Thanks.
kenny nunez
You probably have the electric shift seal which is #313080. Sierra #18-2767
What you need is #909527 Sierra #18-2768 for 400-800 drive.
UtTex
who's aftermarket site did you get it from. if you got it from Amazon, it will never fit.
the OEM 313080 is still available. https://www.go2marine.com/Seal-Transom-0313080-313080-313080-Johnson-Evinrude-OMC
I used to buy all my stringer parts from http://sterndrive.info/
should be item 18 http://www.sterndrive.info/id12.html
it lined up on my 84 stringer 400 back in 2006
Thanks, Scott. It probably was from Amazon, though I ordered it last summer so my memory could be off (it happens :). I ordered from Go2marine this time. Sterndrive.info item 18 showed #313080 for both the 16 and 22 hole variants, so I combined your info with Kenny's and ordered #909527.
UtTex
Thanks, Kenny. That info clears it up for me. Sterndrive.info item #18 shows OEM 313080 for both 16 and 22 hole boots, so I went with your recommendation and ordered #909527.
Go with Kenny's part number recommendation. My memory on the part number 19 years later may be tainted
UtTex
I got the new seal delivered yesterday and installed today. Fit perfect! Thanks!
meantobe63
We have a 1976 Pierce Arrow with the OMC 175 with Stinger electric shift. Do you have the same setup? Ours is electric shift. We need a new boot as well.
Did you pull the drive the install or a gallon of Dawn and some busted knuckles get the job done? Haha. Thanks.
kenny nunez
OMC #313080. Sierra # 18-2767 is what you need.
With some liquid soap or KY the boot can go over the drive, just remove the trim tab exhaust outlet which helps.
