Re: Stringer conversion
If you install a full mechanical drive on your hydro-mechanical upper, you need the mechanical shift cable and the mechanical shift converter with all of it's ESA electronics. That being said, there are things that can be done to your hydro-mechanical lower that modify it somewhere in between without having to go to the lengths above. I do not know the details of this modification but I know an old time OMC dealer/mechanic who does. Problem is, for you, he is in Portland Oregon.
