Stringer motors mounts
Troubled1
My 1980 holiday 181 motor mount wood blocks are rotting. The bolts through the motor mount brackets go through the wood blocks, through the stringers and there’s 4 layers of 1/2” plywood inside the stringers. Does anyone know if the mount bolts are lags going into the plywood or if the plywood is drilled and regular bolts and nuts were used?
Watermann
The mounts I've removed and seen removed have been lag screws.
