a91eagletalon
- Joined
- Oct 17, 2017
- 36
Ok guys have a question I have had this boat for about a year now this is my first spring with it. I am not a newbie with engines I wrench on a lot of stuff. But somewhat of a newbie on the marine side of the engine stuff.
As far as I could tell the boat pumped water never over heated once last fall. This spring I got it out and and got it ready to take to the lake.did a dry land test with the out drive in a really large bucket so I could test to make sure the water pump was working properly. Now when I tested it didn't seem to pump water real well there wasn't much if any coming out the exhaust. So I thought maybe the water pump went bad or wasn't working properly so I ordered parts and replaced the water pump.The old pump was not trashed by any means had one small nick out of one of the fins. But as far as I know I did the new pump correctly. Now after the water pump replacement it still doesn't seem to pump water at idle until I rev the motor up and get it going then it seems to pump water okay.But once you shut the motor off and start it back up it will not pump water until it sees revs then it seems to pump water okay but not great at idle.
I am assuming this is not normal it should pump a full stream of water even at idle.
Do you have any thoughts of what the problem might be.
Thanks
Matthew
Thanks
Matthew
