My bolts that are mounted into my stringer that control my steering are very loose. I noticed I had a lot of play in my steering wheel and after some examining, I found the loose bolts. What is the best way to tighten them up? I have been told to put a couple of shims in the holes and then add epoxy which should provide a temporary fix to my problem. Any suggestions on which epoxy to use or any other way to tighten the bolts without taking the boat out and replacing the stringers?
Ryan
Ryan
