Stringer repair of Beechcraft Cudy
MrMilbe
Hi there,
I’m new here and 1[SUP]st[/SUP] time boat owner. Bought a “lake ready” 1984 20ft cuddy cabin this February and slowly discovered all the little things that make that boat quite not so lake ready :D. (Most likely paid way too much but I’ll book it as a pricey “lessons learned”). I was already in the process of restoring the stringer outboard after finding water in the gear oil ( upper + lower seal kit, new water pump, new ball gear kit, new drive shaft ) and the V8 engine ( this one runs great once its started but needs new exhaust manifolds, electric fuel pump, starter, plugs, hydraulic hoses)
After first taking her out I discovered that the engine mount bolts came out and then after gradually digging here and there and removing more and more of the old floor, the status was:
Transom ( 3 x ¾ ply sandwiched ): 1st layer rotten 2[SUP]nd[/SUP] layer invested with worms, 3[SUP]rd[/SUP] ( outermost) layer fine
Stringer/Engine mounts: back of the boat (everything close to bilge) rotten, front fine, cabin wood + fiberglass in good condition
I already removed all the floor and 2 layers of the transom. I watched a lot of videos about stringer repair and fiber glassing (and got some surf board glassing experience) and I kind of have an idea what to do, but I’m not sure if this is the best way. Also is the boat build a bit different than most designs I found online and I’m a bit indecisive between restoring it 100% original ( that’s recommended on a couple posts) or the way I found in tutorials ( which is simply different from the build).
Although it wouldn’t make big difference in time and material at that point, I don’t want to touch the last transom layer and the cabin. I’m mainly concerned that the cabin somehow falls apart / warps if I remove all stingers and the old material there seems pretty good ( I drilled several 2” holes, fiberglass is thick, wood dry and solid, foam not soaked) so that I think I’d do more damage than good touching it. For the transom it looks like the outer side is part of the fiberglass hull and I don’t want to cut into it.
Transom:
I want to sandwich 2 new marine ply layers to the remaining layer of the transom:
Grind down old glass, soak old ply, then CSM + 2x 1708 + 2[SUP]nd[/SUP] ply + CSM +2x 1708 + 3[SUP]rd[/SUP] ply + CSM +2x1708.
I don’t know what’s the best way of making sure that there’s no air between the ply layers. I can clamp them fairly good where the hole for the outboard is. For the rest I’d drill a couple holes and press them together with screws. I don’t know if there’s a better way of doing this and how many screws I should use. I want to drill as little holes as possible but also don’t want any air bubbles between the layers.
Also the 2[SUP]nd[/SUP] layer had wood worms in there and I was wondering how they got in there at all and how to prevent it from happening again. Isn’t marine ply treated in a way that kills bugs? I’d also assume a completely resin sealed piece of wood doesn’t let any air in so they should suffocate.
Stringers:
So that’s what’s puzzling me a bit. What I found in tutorials are stringers on PBJ or similar, glassed and tabbed from both sides and completely sealed. What I found in my boat looks like they build the floor stringers + bulk heads in 2 pieces ( 2 halves of the boat) and then they flipped it into the boat and tabbed it only on the inside and filled the other side with foam. I attached some pictures to illustrate this. The tabbing is only on the “inside”( there where the tank sits). The underside of the floor is tabbed to the stringers and there is no glass on top of the stringers. The tank side is glassed pretty strong and good, but the side where the foam is, is poorly glassed and therefore started rotting quickly once water got in. I think the idea was that water never leaves the bilge / tank section. Well unfortunately it happened. Also those stringers are only 0.5inch thick but there runs some reinforcement bar in parallel and the whole floor + foam seems to give pretty good structural integrity.
For restoring I was wondering: Should I use 3/4inch stringers instead or stick to the original 0.5 ? Should I tab them from both sides ? They are pretty tall (1ft), do I need to wrap them in all layers all around or is one layer enough to make them water proof and then use only all schedule layers on the bottom for tabbing ? I don’t want to leave the top of the stringers unglassed like the original design. The floor there was screwed on and had no fiberglass on the bottom, except where it was tabbed to the stringers. I would glass the floor on both sides and then PBJ it to the stringers if that makes sense? I also read several times that ppl sand down layers or the filleting area before tabbing. From board glassing I know that poly stays tacky, I would just add another layer of laminating resin, even a couple days after. Is sanding necessary?
For connecting it to the old stringers I attached a drawing. I don’t know if that’s a good way to do it and if I should somehow reinforce the joint.
Depending on your recommendations I like to figure out how much glass and resin I need.
Schedules I found are: Transom/Stringer CSM (1.5oz) +1708+1708, Deck 6OZ cloth both sides + gel coating top, Filler: Cabosil + Poly resin 1:1
I found a hint on how much resin per sqft to use here: https://www.lbifiberglass.com/how-much-resin-glass-do-i-need/
If I stick to the schedule above I’d need 58sqft CSM, 117sft 1708, 95sqft 6oz sloth + 8Gal resin
Is that realistic?
Thanks for your help. Hope my mix of thoughts and questions is not too hard to read.
MrMilbe
Hi there,
I’m new here and 1st time boat owner. Bought a “lake ready” 1984 20ft cuddy cabin this February and slowly discovered all the little things that make that boat quite not so lake ready :D. (Most likely paid way too much but I’ll book it as a pricey “lessons learned”). I was already in the process of restoring the stringer outboard after finding water in the gear oil ( upper + lower seal kit, new water pump, new ball gear kit, new drive shaft ) and the V8 engine ( this one runs great once its started but needs new exhaust manifolds, electric fuel pump, starter, plugs, hydraulic hoses)
Transom ( 3 x ¾ ply sandwiched ): 1st layer rotten 2nd layer invested with worms, 3rd ( outermost) layer fine
Transom:
Grind down old glass, soak old ply, then CSM + 2x 1708 + 2nd ply + CSM +2x 1708 + 3rd ply + CSM +2x1708.
Also the 2nd layer had wood worms in there and I was wondering how they got in there at all and how to prevent it from happening again. Isn’t marine ply treated in a way that kills bugs? I’d also assume a completely resin sealed piece of wood doesn’t let any air in so they should suffocate.
Stringers:
Is that realistic?
MrMilbe
Hi there,
MrMilbe
Sorry got a Server Error and posted again and now I see its multiple times there. How can I delete this?
MrMilbe
Sorry got a Server Error and posted again and now I see its multiple times there. How can I delete this post? Everytime I click on "post" I get the message below
first, no such thing as a lake-ready 37 year old fiberglass boat unless it was recently restored
second your transom should be 2 pieces of 3/4" or 3 pieces of 1/2" the wood core is only 1.5" thick. because the finished product is between 2.0 and 2.125" thick
make sure you go thru links 14, 15, 18, 2, 3, 4a, ans 4b in the DIY sticky at the top of the forum. all the answers are there.
that is the beauty of this site and the stickies at the tops of the forums..... 99% of the information you need is in there.
your V8 has a mechanical fuel pump. replace the mechanical fuel pump with a mechanical fuel pump
you mention ball gears, so i assume this is an OMG stringer 800. you really need to inspect the vertical drive shaft splines. if they havent stripped yet.....they will soon.
you need special tools for servicing the upper, and a good factory manual.
no marine plywood isnt treated other than initial kiln drying to kill insect larva when they made the plywood. marine plywood is simply wood layers glued together with waterproof glue. Marine plywood is not rot resistant, its just a slightly better version of exterior grade plywood.
if you have insects in your boat, you need to eradicate them first.
you do have your motor out and a cradle built, correct?
MrMilbe
How? Do I Flag my own post? So I suppose there is no hidden delete button...
MrMilbe
Hi Scott, thx for the infos.
Yes I have the engine and outdrive out and got a couple parts ( e.g. drive shaft) that needed replacement. I havethe manual and access to a lot of tools, but wanted to open a different post if I have engine or outdrive related questions ( I actually have good knowledge about engines, only that whole boating thing is new to me, I'm positive about replacing my mechanical fuel pump with an electrical one ) .
I read the sticky, a lot of forum posts and also watched most of the great videos from Boatworks today. The answers I couldn't find are related to keeping the old boat design vs doing it the 'normal' way.
I read that I should stick to the old design as close as possible and that making it stronger is not always better as it might create stress points. However the way they did it is not easy to replicate and its also not how its done in all the tutorials and guides.
Most urgent questions atm ( for ordering wood and fiberglass):
Should I stick with 0.5" stringers or go for 3/4" ?
Should I glass them completely in all 3 layers on both sides ( CSM + 2x1708) or should I just tab using 3 layers and apply one layer all around for water proofing ( the stringers are 12" tall so that makes a big difference ) ?
I also read different instructions how long to extend the tabs. Up to 10" the longest tab. But my stringers are only 20" apart, that would cover the whole floor. The original tabbing is not wider than 2".
I know the transom is normally thinner, idk if it got replaced already once or the previous owner just sandwiched one on top ( that might explain the wood worms in the middle). But I definitely removed already 2x 3/4" ply and got still one 3/4" left. Should I just add 3/4" plywood then ?
One last thing, I read a lot of good things about Arauco ACX, the local wood supplier told me only to use marine ply. You think that's just a "make money" thing? Putting in total 5k in that boat so a few bucks don't make a difference but I also don't want to waste money without any reason.
MrMilbe
Sorry for reposting for the purpose of cleaning up, but that was the last post / question :
