Stringer repair
CoachSteve
Attempting to repair or replace stringers, and have many questions. Number one, I have ripped up the floor and foam out of boat, but towards the back and front of boat, it's sandwiched between the top and bottom half of boat. Please see pictures. How do I get access to these area's, do I need to cut these out? Number two, when I go to put the foam back, how do I put it in and exactly how much do I add?
Thanks in advance
http://www.imagestation.com/album/pictures.html?id=2104898435
OHfishing
Re: Stringer repair
I just got done playing with a&b foam and I have some advice....mix in small amounts until you get used to using iit, and use a new container to mix & pour each time.
tommays
Re: Stringer repair
On boats of that style you may have to remove the rub rail and other stuff holding it toghter and sepperate the upper and lower hull :(
Tommays
CoachSteve
Re: Stringer repair
Tommays,
So by removing the rub rail I can seperate the top of the boat?
tommays
Re: Stringer repair
IT will be a littel harder than that it depends on how well they built the boat
But thats the general idea
Tommays
dmarkvid2
Re: Stringer repair
There ia a slight chance that the portion of stringers in the bow area may be ok. I say that because If the boat was trailered, it was most likely tilted with the bow upwards for drainage. Right? The majority of water is in the back half of the boat. The transom area I'm sure you'll have to take care of, (Mabey the transom itself) you'll probabably want to check that area out good, If you find that the stringers by the bow a ok, then you can sister them together, and glass, thats if you can get to them. good luck!
