stringer replacement
tdetra
I have a 22ft silverline that has rotten stringers. Ihave pulled up all the rotten wood and almost ready for glassing. My question is what thickness of mat should I be using and how many layers.Example: two layers of 1 1/2 oz mat or one layer of 24oz. double bias. Or am I in need of a better book.
Boomyal
Re: stringer replacement
What exactly is it that you are ready to glass??
BillP
1.5 oz mat, 18 oz woven roving, 1.5 oz mat, 18 oz woven roven.
Boomyal
Originally posted by tdetra:<br /> 1x7x12 doug fir to the fiberglass hull
I hope you have pre-treated these with epoxy?
barbender55
You may find that with the heavier 18 oz mat that it will not adhere to the top of the stringer. You may get a bit of a cap on it. This is because the mat is a tad to heavy so you may have to slice it down the middle. I had this problem last week and almost decided to end my rebuild with a match!
