Stringer Replacment
sledjunky
I am going to replace the stringers in my 1985 aerocraft mach 2 the problem is that I want to rip out and clean all surfaces and get it ready to put in the new ones . but I think it would not be warm enough to glass in. can I move the boat on a trailer with rollers without the stringers in it to storage with out any problems?
Gypsystar17
Re: Stringer Replacment
usually you have to block the boat level,remove stringers,install new ones and floor to keep everything aligned.
you should be able to move it on trailer carefully not to crack the hull,just make sure you get everything level,front and back before you install stringers.
sledjunky
Ok would it be ok to just do 1 stinger at a time and keep on roller trailer? I have room restraints and need to keep on trailer
