Stringer Swap For A Cobra
Can you interchange the Cobra models w/ a Stringer 800? If so How diff? I mean can I just change the Outdrive? Thanks
flabum
Re: Stringer Swap For A Cobra
To switch to a Cobra drive, you will need to fill in the hole in the transom and re-cut for the Cobra. You will also need to get a transom assembly, drive coupler and flywheel housing. If you go that route, go for a Volvo SX drive.
Don S
Nope, nothing is the same but the engine block.
Ayuh,.........
Updating a Stringer is a Major Refit,...... Regardless of What you want to put back in..........
And,.......
Up dating to another OMC,....... Well,... It just Isn't Up dating a Thing.......
KaGee
Ayuh,.........
And,.......
Sort of like updating an Edsel with a AMC Pacer. :D
