Re: Stringers on a 34 foot boat!!!
This is going to sound a little negative but it may be an issue you have to deal with. Hopefully your stringer problem is limited to just that, a stringer or two. Otherwise, it could involve as much as having to grind away the entire hull exterior fiberglass and rebuilding it. I would start by researching the problem Sea Ray has (or had) with boat hulls that allowed water into the core. Some owners spent tens-of-thousands of $$$ to repair the saturated core problem. From what I have heard, Sea Ray said not my problem, your outside the warranty period, but I don't know if this is true. Dont know what models or years so you should check into it, unless you already know your boat hull is ok.
