Re: Stripped Anode Bolt
Others have had the same problem and the fix was to destroy the old tab off the bolt (they break apart pretty easily) and maybe it'll loosen off the bolt. If not, then split the drive, since you now have access to the bolt holding the trailing edge of the upper and lower drive sections together that the tab concealed. Now you'll clean access to both the bolt head and the tab section. Vise grips will be your friend then.
