Re: Strongest alpha one u joints
i'm mostly have questions.
I run a bayliner 2050 with a mag mpi 350 (330 hp).
isn't that about 30hp over the generally considered max hp rating of a alpha1. i understand it's gears and brgs that don't like the extra hp too. i don't know about the ujoints. if bravo and alpha are the same. that would seem unlikely..
We usually have about 700-1500#s ballast in it
since yer wake boarding. i assume the weight is aft. seems like a lot of weight. don't that make ya go bow high when ya take off. sounds like extra work for everything to me.
I'm going to have to check my alignment then. Cause the last set only lasted a season.
i'm under the impression that's a once a year inspection. if it were off, i would think the coupler would be affected, not the ujoints.
i might of been running trimmed up to far.
why do you think that. you ventilating? pointing bow ski high during hole shot? do you porpoise? do you ventilate in turns?
i never hooked up the trim limit switch
you shouldn't need a limit switch. you should be able to tell by how your boat performs. you go to high, adverse affects happen.
when i turned, it would start to growl and vibrate.
growl does sound like a description for a bum gimble brg. who installed it. was it done proper? turned and vibrate does sound like a description for bum ujoints. how old is the boat? maybe it is time to R&R them.
i do raise the outdrive to clean up the lip of the wake
perhaps trimming is done different for when your wakeboarding. but i have trim full in till i get to about the speed i wanna go, then trim up for max rpm. speed increases as this occurs as the boat lifts further out of the water. trim to high and rpm increases w/o speed increase, ventilation occurs, bow high occurs, porpoising can occur.
and it seems like i have to raise it more when i have the ballast sacks full.
where are the sacks? back, middle, ft. my guess is back, which i'd think would mean more trim in to maintain proper plane.
like i said, just observations and questions out of me.
as for the hd ujoints. i wasn't aware they came heavy or not heavy. when i did mine, i just went oem. the assy. looked similar to the one ya got marked hd. mostly similar since i got both straight and offset grease zerks and extra c clips with the oem product.
good luck with her...
http://www.clubmarine.com.au/internet/clubmarine.nsf/docs/mg19-2+technical
