struggling to plane
itswink
I have a 2006 crownline 200 ls with a 5.0 mercruiser SN:OW355448. This thing HATES to get on plane. It doesnt even like to plane out with just 2 people. When I have 4 or 5, it takes a while to plane. Once it gets up on plane and starts setting the bow down, it takes off. This is about 20 mph. Once it reaches about 3,500 rpm, it SCREAMS. I mean it sets you back in the seat. Until then, it is a dog. I am running a powertech 4 blade 17 pitch prop.
what gives?
EDIT. also added smart tabs.
Re: struggling to plane
is your drive trim all the way down?
itswink
with a boat load, i move everyone to the front and it still takes forever. it gets embarrassing.
markheck1
I wonder if the foam got wet and you are carrying a bunch of extra water weight?
or possible a timing issue, is it smooth all the way up through 3500?
I assume it's always done this, you haven't had it very long?
or did this start lately?
scoflaw
Ensign
Prop diameter too small? Is it lugging or overrevving when trying to get on plane? What RPM does it top out at?
itswink
It's lugging to get on plane. It tops out Around 4600 (close to max). It just seems like at a certain point you hit the nos button and it runs.
It seems slower than it used to be. I guess I could drop prop sizes again, but it seems to me like it would perform better out of the hole.
itswink
And yes, motor seems to be running smooth.
Maybe I am just expecting too much from it.
spdracr39
Could be a timing issue with the motor. You should have plenty of power if everything is working correctly. Get someone to read the codes and make sure the motor is running right.
scoflaw
Ensign
Full tuneup with a compression check would be a good starting point. Try your original prop as well. That boat with that motor should jump out of the water.
Don S
What is you maximum WOT (wide open throttle) rpm?
itswink
It's getting close to 4800 2 people and a big full cooler. Max is 48.
What does one need to check the codes?
I More offer have 4 or 5 people though and all their gear.
Don S
I'm moving this over to the prop forum, doesn't sound like you have engine issues that are causing the problem.
itswink
I guess im going to try a 15 pitch. I am running powertech ele 4 17 pitch now.
I just have this idea in my head that I shouldn't have to prop that boat that low.
It runs below 3000 rpm when trying to plane at full throttle. Should it spin up more than that?
itswink
I took the boat out yesterday and it didn't even want to plane out with just two people. The engine is really lugging until it reaches higher RPM. It did not used to have this much problem getting on plane. Something has to be wrong but it seems to be running smooth.
