SkiDad
- Joined
- Jul 18, 2010
- 1,518
i picked up a lower unit 3 years ago that works great but could never get the drain plug loose - i cranked on that puppy with the correct 5/32 allen wrench - bent the wrench pretty good - then tried another. Eventually stripped it out - then tried a few torx sizes - i think i had used a few cheap quality T25 torx and no luck. I gave up 3 years ago and have just been draining it by taking out 1 bolt in the prop spool behind prop anode.
i wanted to try again this year and used this AeroKroil and let it sit for 30 minutes. Then came back and hit it again - in the mean time I picked up a better quality Torx T27 - pounded it in there and turned and it came loose. I'm really sure the AeroKroil was the main reason it came out
NOTE - wipe off excess as it can take the paint right off (as you can see in the picture)
