Re: stubborn hull residue
What oops said im sure is true, but this is what i did and it worked awesome and it may be easier to find. if its the brown lake scum, lysol brand toilet bowl cleaner works GREAT. HAS to be the one with NO bleach, the bottle is blue and white with the crooked neck. i put it in a pump sprayer, straight, (garden sprayer), and sprayed it on the DRY hull. used a DRY foam mop to spread it around. no need for scrubbing, just let it sit min or two and you will see it just turn the brown to bright white before your eyes. careful, it will stain a galvanized trailer, if you wet the trailer first it helps but do not get the hull wet. i did it to my boat and couldnt believe it. HAS to be the lysol brand though, apparently it makes a difference. smells clean when your done too!!!
