slag
- Joined
- Jul 17, 2009
- 471
I'm at a loss. I've rebuilt my carb and it idles perfectly, gone through a couple tanks of fuel, rechecked the carb, changed my fuel filter down by the oil filter, cleaned my points, set my dwell and timing, and still, I'm stuck at 3k rpm and about 30 mph on this 1989 Regal Medallion boat. Using a 17 or 19 degree pitch prop makes no difference, rpm stays the same. It will get up to around 3100 rpm when trimming, but no more.
Ideas? I'm stuck. The boat is firing on all cylinders and all plugs look good, but I'm about to change out the plug wires and plugs just because I can't figure it out. It runs smooth at idle and up to speed but stops short at 3k rpm. When looking down into the engine, the throttle plate is fully open.
Distributer cap and rotor look good as well.
EDIT: Two people or 5 people, it doesn't matter. RPM stays the same.
