Can’t decide between 3 blade 15.6 x 19 or 15.6 x 21; both Turning Point Mach 3 OS (SS)
Current issue: 6100 rpm at WOT (24 kts) 4500 rpm at cruise (19 kts) trying to get to cruise of 3200 rpm and WOT around 5000.
Current setup: 26’ Cruiser, 260 Holiday, 8.5’ beam, 5200 + 400 in load= 5600 gross weight
5.7L Vortec 350, 312HP, OMC stringer drive, 4 blade dual pitch 15 x 15 (15/17 pitch) Turning point aluminum propeller.
Not sure of the rpm change from 4 to 3 blade. I understand that each degree of pitch increase will decrease 200rpm some say 300.
Should i switch to 19 pitch? 21 pitch? Or am I way off the mark? Please help if you can and thank you in advance.
