Re: Stuck Gimbal Bearing
hello<br /> I have experienced this on occasion.<br /> there is no snap ring on the SX. the bearing is technically able to rotate 90 degress and be removed from the notches. however the manual says the notches face fwd when installing so you have to remove the entire thing to remove the bearing. the wavy metal strip is called a tolerance ring. it cannot or should not be reused if removed.if your puller has 1/2x20 threads them buy a length of stainless all thread. place your puller in the gimbal bearing. use a thick metal plate that will fit between the mounting studs with a 1/2 inch hole in the center use a large flat washer with grease and a nut to act as a draw nut. it will appy more pressure then just a slide hammer. takes longer but some times I have to use it.good luck and keep us posted on how this comes out
<br />PS I found out a few years ago what happens sometimes when the bearing is placed with the housing notches af. it allowed the bearing to **** slightly on the drive shaft the next time the customer tried to remove his drive. they brought it to me you could not pull the drive nor reinstall it. I had to pull the motor and use a large brass bar(3"x 2.5 ft long)
to drive the shaft and bearing out of the transom assy. that is why I follow the manual and put them in just like it says. the killer thing is yamaha I think says notches aft
