Workin on an 88 maxum,350 mercruser,A-1,came in for spring maintaince and found drive FULL of water,drive bellows GONE,pressure tested on boat and could hear it leak out yoke seal so we TRYED to pull the drive with minimal luck.After tryin everything we could think of it was drive in the pry bars between the bell house/drive time.Well,she separated alright,now we have a drive which no longer has the input shaft/gear/retainer/bearings in it!The million doller ?? is,how to get that#%!#%? shaft/g,bearing out of the transom house? We went sofar as to put a chain through the UJ.and put it around a tree and yanked/snatched it 3 times with no luck!(23ft.boat WAS attached to the trailer with 2 ,2" straps on the rear and the winch strap on the eye.)After we got the boat back on the trailer we just put it away for another day.Think you can remove the engine with this shaft still in it and then MAYBE sledge it out?The bearing turns while cranking but the retainer and the shaft R frozen tight!
