Stuck In Reverse
woodbswift
I replaced the impeller on a 2 stroke 5 hp tohatsu outboard. When everything is assembled, the shifter won't come out of reverse. The shift rod an coupler move all the way; but, the shift rod coming up from the lower unit does not. seems to be stuck in reverse.
Any help will be appreciated.
Wood E
GA_Boater
Welcome aboard, woodbswift
This is your new thread, moved out of an old thread. Look at he Help Tip on top of the page.
pvanv
Always replace the entire water pump kit, not just the impeller. Lasts longer and pumps better.
You must have the brass shift coupler in the proper position, or it isn't tightened. If the LU is in R, set the shift lever in R, and tighten the coupler. Then check. You may then need to make a slight adjustment.
