JASinIL2006
- Joined
- Feb 10, 2012
- 5,715
Hi all, I've embarked on trying something I've not done before: changing out the wear components on my 2005 4WD F150 front end. After 100,000 miles, I needed new ball joints and struts, so as long as I've got everything torn apart I'm replacing the upper control arms, lower ball joints, struts, stabilizer bar links and tie rod ends.
So far, I've finished one side and I'm about 60% done with the other side. I'm getting hung up on what should be the easiest part of the job: getting the old outer tie rod ends off. The jam nuts that snug up into the tie rod end don't seem to want to budge, despite being treated repeatedly with rust penetrant and having the exposed threads cleaned.
Any ideas on how to un-jam the jam nuts without completely buggering up the whole tie rod assembly?
Thanks!
Thanks!
