Hi All,<br /><br />I have a 1969 Chrysler 9.9hp short leg outboard.Last week I struck the prop on a hidden rock.I lost forward and reverse and was leaking oil from the lower leg just above the prop.I did everything my manual said on how to remove the lower unit but it won't come apart. I even tried to remove the engine from the unit but it also is stuck.Could it be possible that the drive shaft is corroded to the engine and lower unit?(since it is a 69!) Is there a trick to free the shaft from these components?
