DollarBill
- Joined
- Jan 5, 2003
- 1
I need to replace the water pump on my 1985 30HP Johnson. I have owned the motor since new and the lower unit has never been off. I have removed the four bolts which attach the lower unit to the mid-section and the single nut on the threaded stud at the front. The shift linkage is disconnected. I can't get the lower unit to separate from the mid-section. It hasn't dropped at all. It appears that the back portion is free but the front is being held fast. I wondered if salt build up around the front stud could be the problem or whether the drive shaft spine could be binding in the crank shaft. Any advice will be greatly appreciated? Thanks
