Stuck on windshield restore
chrisvr6
I'm missing the walkthrough center windshield and the window gaskets are not any good on the rest of it. Does anyone recommend a place online that has windshield frames and gaskets. Thanks.
oops!
Re: Stuck on windshield restore
iboats sells windsheilds...
and what kind of gaskets are you wondering about?
the gasket between the frams and the glass is a rubber u channel......and the gasket between the hull and frame is weather stripping.
by the way....welcome to iboats !
what kind of boat are you working on......there may be many used pass thru doors avalabile in your area
chrisvr6
Its an '89 sea sprite 175. I need the u channel stuff for betwern glass and frame. Oh, and the frame pieces to make the center glass from scratch. Thanks.
Bob_VT
For the framework.....try a local glass shop for the aluminum framing. The hing is usually a stainless steel piano hinge available at hardware stores.
Oops! do you have a link to the u-channel gasket?
