Stuck rings
toybuilder039
I am in the process of rebuilding a old 5.5 hp that's been sitting for ever the engine was seized from sitting but finally got piston out the cylinders look good but rings are stuck in pistons anyway to free them without destroying the rings thanks
boobie
Re: Stuck rings
Get a bucket and mix up some ATF and Acetone 50/50 in it. Put your pistons in it and let them soak for a week or so. Occasionly give the rings a light tap with the handle of a screw driver. PATIENCE is the key here.
HighTrim
Re: Stuck rings
Hopefully they free up, but you may want to replace them regardless depending on their condition, especially since you already have the pistons removed. Do not want them breaking inside the cylinder, then you are into a whole other ball game.
Mas
Re: Stuck rings
I think I would re-ring as well...since you've got her opened up!
Mas
jimmbo
Re: Stuck rings
I would be more worried about damaging the piston while removing the rings and cleaning the grooves
1946Zephyr
Re: Stuck rings
Yep, boobie has the best advice here. Soak the pistons for a week or so, but go ahead and replace the rings with new, once you get the old ones out.
