Stuff under the sanded fiberglass and more rehab SportCraft 222 progressive
kcassells
Tried to post this earlier but got bounced into another nether world.
Sum it up;
Kicked butt, found some odd discolorations under nearly grinded out hull fiberglass in addition to a long slurry of resin inside/on the bottom of my hull.
Any suggestions? Want to wrap up the wood, glass, floor before that stuff gets buried. I think my boat was made on Fri. after a liquid lunch. Resin had no glass in it, but it shows cracks, some I found had water still under it. On another note there are alot of glass spots with wet foam under that. Has anyone seen that before?
Pics may tell the tale. Thanks for your feed back. My other attempt to post was more detailed.
The wet foam stuff under the glass was in alot of different areas. The green slime under the glass may be mold/foam/spilt beer etc.
Just probably will grind er out but the variables/info and be appreciated.
kcassells
Re: Stuff under the sanded fiberglass and more rehab SportCraft 222 progressive
Just want to start to get the wood in. The itch is back and so is the weather!
kcassells
some pics with sun finally out again.
kcassells
Anyway....Sanded out the overpour of resin. I just had to. And that was all it was. Now the gravity flow of water is perfect. In addition, after a day or two in the sun the dark spots cleaned up after a quick grind.
Thats all signing off this thread.
